Logix5k Battery Low/Battery OK
rootboy
Jan 2004
Tennessee
1,375
I've got a bit of a conundrum here where we monitor the state of the battery in the PLC by looking at bit 10 in the Minor faults.
It's reporting that it is "not low" while the "Battery OK" icon in ControlLogix5k says that it is not OK. Any idea what's going on?
Thanks!
Thanks guys, that was going to be my next step, to have one of our electricians yank a battery in a PLC and see if the fault sprang up.
As an aside, I used Archie's AdvancedHMI to poll all eighty of our PLCs in our Paint shop for dead batteries. Works great. :)
Thanks again! :)
Just tell them to not accidentally power the PLC down with the battery out! It does seems strange to me that most other LEDs are red/green and that one is off/red. Maybe there's a method to that madness.
AdvancedHMI is pretty sweet. I find all kinds of usefulness with it, and VB in general.
Well, yeah... :)
Besides the last knucklehead that shorted a supply while the PLC was running was, uh, me. :)
Yeah, that's weird, not as bad as GE's use of red LEDs to indicate that things are going okay though.
And I've got a couple of AdHMI apps running here. The battery monitor one (which only needs to be run every quarter or so), and one that reads the temperatures of the heat exchangers. One of our Process Engineers wanted a way to log the data once a day, and I wanted a way that wouldn't involve me doing it more than once, ever.
I had it working with RSLinx, but after the grace period expired and our librarian declined to provide a license for RSLinx for a once-a-day reading, it was time to try out AdHMI.
I had to edit the dispose sub to get AdHMI to truly dispose of an entry, but other than that, it was smooth sailing.
And thanks again for the LED lesson guys!
Hi all, I'm starting work on a system and the processor for said project is a Control Logix 1756-L82. When I open Logix, however, that CPU is...
2,948
Hello, I have been working on an alarm tracking routine. I take several bits to get a status of a device and load then into an INT Dev_Stat. When...
1,015
Hi all, I'm working on some Control and Compact Logix A&B PLCs, running Logix5K version 24. I've been doing online edits just fine, but I've...
2,440
From what I can tell, AB's Connected Component Workbench (CCW) does not support CompactLogix L43 with RsLogix v20.xx Software. What are my...
2,719
Hello PLCs.Net! I am trying to use RSLogix5k via windows command line. I would like there to be a script which automatically opens a project...
1,248
