Logixpro PLC Simulator - Exercise 7-18B: Assistance Needed =)
Pish
Sep 2009
Pa
I am taking a PLCs class toward an assoc. degree in MET.
I am working on Exercise 7-18B in the
Programmable Logic Controllers (third edition) Lab Manual and having some difficulty with the logic.
The exercise states:
Modify the original program so there is a 2-s period when both directions will have their red lights illuminated. Use additional timers TON_T4:4 and TON_T4:5 to implement this change.
I attached a jpeg of my logic thus far. I have timers TON_T4:4 and TON_T4:5 inserted into my logic but am not quite sure where to place them as well additional logic to correctly get my lights to function as stated above.
Any help is appreciated, thanks for your time =)
The timers that turn on the green lights now have to be changed to your new timers, hence the timers that did turn on the green light now have to turn on the extended red light time.
Notice your time base. You have some very fast acting stop lights.
Please document your timers. Do it as you add it.
P.S. (T4:0/EN [ ] and T4:0/DN [/]) is the same thing as one T4:0/TT [ ]
I'll also make the suggestion that you make a diagram of you light outputs. "Professor Bill" has on in his student exercises. If you'll make the timing diagram you can see exactly how many timers you need, how long each of them comes on, and the sequence order to put them in. Don't try to do this in your head! Making a diagram will work...and it has been my experience that if you can't make the diagram, you'll not be able to get the timer sequence correct either....at least not by yourself.
Michael
Thank you both =) I am going to work on it and see what I can come up with. Your suggestions and direction are very helpful!
hello, all! I'm tryin to design this ladder diagram for a project me and my friend are doing that have to do with a rail road crossing at a road...
38,101
please? I'd appreciate it. It's for a final project due for my control systems class.
4,926
SELECTED NEW FILE SELECTED PROCESSOR TYPE SELECTED I/O CONFIGURATIONS IM UNABLE TO CONFIGURE MY I/O’S. I HAVE A PAPER COPY OF A PROGRAM AND I...
81
Good morning, I am currently working on the LogixPro Advanced Batch #2 Multiple Mode of Operation and got stuck very close to completion. Link...
2,241
Hi folks, i'm pretty much new on this topic and i need some help with the dual compressor part 3 and 4, currently working on part 3 i cant make...
20
5,135
