the file opens OK in LogixPro ... the screen shot DOES show ALL of your program ... (hint: you don't have to worry about "double-coils" at this point of the game) ...
the information I provided in my first post should be enough of a hint to get you going ...
but ...
if you need more help than that, I suggest that you go through the following line of reasoning ...
Step (1) ... first ask yourself, IN ENGLISH (not programming) the following question:
"WHEN do I want the Fill Lamp to be ON?" ...
Step (2) ... then answer the question, IN ENGLISH (not programming) something like this:
"I want the Fill Lamp to be ON when – blah – blah – blah" ...
once you've defined the operation IN ENGLISH, then (and ONLY then) are you ready to start TRANSLATING the English definition into a programming language ...
apply what you know about ladder logic to rung number 001 in your program ...
if this approach doesn't work, post the results of Step (1) and Step (2) here on the forum and we'll help you work it out ...
