Look up table Calculation for Modbus
ahsen001
Mar 2010
Dubai
25
Hi to All,
I m new in Modbus. I want to know that how to make or get the Modbus Lookup table for communication between two PLCs or you can say between PLC and DCS.
If i have I0.0 at Siemens plc as a Digital Input, then what will be its Equivalent Modbus address which i would call at Master PLC or DCS for writing or reading whatso ever.....?
Same as i have a data in Data Block like DB1.DBW0 then what would be its equivalent modbuss address....?
Thanx in advance.
Regards,
Hello ahsen;
There is no one-to-one conversion table for Modbus registers and Siemens S7 registers.
Everything depends on the parametrization that you decide to setup in your master or slave program (in the S7 CPU). For example, ypou decide which is going to be your Base Register (start addtess) for a specific Modbus Function; then everything is calculated based on offset and ranges ...
Actually, it is more critical when you are setting the S7 PLC as a Modbus slave.
Have a look at a recent discussion on another forum, look up the attachments and study the proposed manuals, they should help you clear the issue out.
https://www.automation.siemens.com/...ow.aspx?HTTPS=REDIR&PostID=219148&language=en
Hope this helps,
Daniel Chartier
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,173
I've asked this before but I still couldn't make it work. I just can't envision a solution. Local RTU has a screen to set a handful of...
18
1,576
Since upgrading to V6.2 12.24 SP12 24-21 the M221 PLC is no longer recognised by the HMI. The screen still works but it does not talk with the...
1,010
Hello, Does anyone know if there is a portable version of RSLinx Lite (even an old one)? I am wondering as I am trying to put together some tools...
692
Hi. I'm working with a SLC 5/05 but I have no experience with it. I've been tasked with trying to figure out if it is possible to directly modify...
1,080
