Looking for a relay with a small footprint
damiens
Mar 2009
Columbus
42
What I'm trying to do is essentially make a strobe light. I have a lighting machine what uses 110 for the output for the lights to create lightning. I also have a 100w led that runs on dc 34v. I'm trying to find a relay with a small footprint that will be fast and play nice with everything.
I'm considering an option from TURCK but it is pricey.
https://www.valinonline.com/products/css-n13x-dc5-48v
Any suggestions? Thanks.
Digikey has lots of options but you're going to be looking at more money for a 120v one (https://www.digikey.ca/product-detail/en/phoenix-contact/2903336/277-10093-ND/4755345)
than a 24vdc one (https://www.digikey.ca/product-detail/en/phoenix-contact/2903359/277-10083-ND/4755335)
Or you could solder one in yourself for the cheapest (https://www.digikey.ca/product-detail/en/kemet/EC2-24NU/399-11037-5-ND/4291103)
Finder makes a nice terminal block relay that I use a lot. Comes in mechanical or solid state, various voltages as needed. Also re-branded as Allen-Bradley.
Lots of companies make something similar.
As Rupej pointed out. I carry spares around with me when commissioning: https://ab.rockwellautomation.com/Relays-and-Timers/Terminal-Block-Relays
Good Afternoon , We have a number of MSR127 Safety Relays on various machines. We had an issue a few months ago that we had a EStop...
3,739
Good Afternoon , We have a number of these Allen Bradley GuardMaster Safety Relays in the plant. We had a problem with a safety circuit...
1,956
Hi guys, I'm going to replace our mercury-wetted relays with Solid State relays and I'm looking for advice on what you would use. The current...
2,769
Has anyone run across a low voltage (12-24VDC) timer relay? I'm looking for something pretty compact maybe even PWB mounted, with preferably...
2,703
I am looking for the "right" type of industrial UPS but am not having much luck so far. The one feature I am looking for is a alarm output, no...
5,208
