Looking for housing for transmitter
MrQ
Feb 2005
236
Hello,
I have a PH transmitter that is supposed to be panelmounted. The cut out is 90*90 mm. This is some standard measure as I understand.
However I do not wan't to panelmount it instead I wan't to wall mount it. However the supplier for the transmitter has no housing that can be used for this.
Any one have any suggestions. And no, I do not wan't to by a housing and make my own hole since it is about 100 seperate units and there has to be some kind of standard housing I would imagine. Plastic is fine.
I think you may end up having to get blank boxes and then make the holes. I wouldn't do the job yourself, it is an easy and quick task for a CNC milling machine, though machine shops can get expensive. To look at saving cash I would contact a local engraver (the people who make panel labels) and give them a go, they have the computer controlled machines and are used to cutting plastic.
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
205
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
146
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
788
I downloaded v24 for studio 5000 but can’t find where the download manager put it! Any help? I’ve done it before but can’t remember. Thanks
395
