Looking for info on Controlware
ndzied1
Aug 2002
Chicago, Illinois
2,857
I have a customer with a system that has an open controller in an Allenbradley SLC rack. It appears to be a computer that is sitting in the first 4 slots of a rack and has the p/N 1747OC-EDAAA In the first slot which I believe is the actual PCU and RAM unit.
Next to it are a VGA slot, a PMCIA slot and an IDE slot.
The thing programs in somethign called Controlware but I'm having difficulty finding anything about it online.
I found an AB press release from 1999 about it but not much else on if anyone took it over or if there is a migration path to newer technology.
Any insights appreciated.
Thanks,
AB sold an "engine" that enabled programming the OC using IsaGraf. I can't recall whether that was called ControlWare.
There's a company in Montreal (forget the name) that took over IsaGraf and did some systems using the OC.
Good Afternoon , I am looking for Industrial Ink Jet Printers that mark cases of product with Bar Codes , Lot Numbers , etc. I'm looking to...
2,029
hello all .. this might be Out of the topic but just hope some had come thru or know something about it . looking for supplier for 500L SEED...
1,453
Has anyone used one of these protocol converters like the Redlion or others to get data from Frick RS485 or Ethernet units? Customer has both...
2,893
Hi all We were trouble shooting one of our machines this morning and found a bad prox. switch. We stole (or should I say borrowed) one from a...
4,073
Where can I find information about the DH-485 hardware requirments like normal voltage outputs for the network between two 1747-AIC unit and from...
2,356
