Looking for Portocol converter to get Frick info into Logix5000
JaxGTO
Apr 2009
Kalieefornia
1,071
Has anyone used one of these protocol converters like the Redlion or others to get data from Frick RS485 or Ethernet units?
Customer has both Frick Quantum LX (has Ethernet) and RWB II Plus (has RS485)
Thanks, Jack.
Frick Quantum LX uses Ethernet/IP protocol
Thanks, Jack.
Hello Jack;
I found this information on the web:
From the Frick (by Johnson Controls) FAQs:
http://www.frickcontrols.com/pages/faq#q23
23. my Quantum LX communicate via Ethernet to my PLC?
• The Quantum LX will communicate via Ethernet using Modbus TCP or Ethernet/IP protocols. The Ethernet communication setpoints can be found in the Quantum LX Menu at Configuration>Ethernet. Detailed information regarding the Quantum LX Address ranges that are available to the PLC can be found in the Quantum LX Communication Setup manual, 090-020 CS.
If your Controllogix has a 1756-ENBT module or any other Ethernet/IP communication processor then you can integrate the Quantum LX directly, without a gateway or a protocol converter.
As far as the RWB II controller is concerned, I cannot find information on the protocol it supports. If it is Modbus, or Profibus-DP (over RS-485) then Prosoft has rack-mounted processors that can be added to the Controllogix rack to integrate it directly.
So if you can find this information we can help you further.
Hope this helps,
Daniel Chartier
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
204
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
146
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
786
I downloaded v24 for studio 5000 but can’t find where the download manager put it! Any help? I’ve done it before but can’t remember. Thanks
393
