Looking for info on a Prox switch
mrdegold
Mar 2003
croydon pa.
80
Hi all
We were trouble shooting one of our machines this morning and found a bad prox. switch. We stole (or should I say borrowed) one from a newer unit we have in storage. Although it was not an identical switch the machines were made by the same manufacture and both switches perform the same function.
My problem is I would like to get the specifics of the switch before I order new ones to replace the “borrowed” one and put 1 or 2 into spare part inventory. But when I look for the switch on the web I only get confused.
I’m hoping someone can help me out. The label on the switch reads.
automatisme & controle
38180 SEYSSINS- FRANCE
DPA5 K 0-10V
24VCC
I’m not so much concerned with getting the exact same manufacture as I am with getting a switch which is electrically the same that I can just drop into place. If I could get the specs I could then easily match it up.
Thanks for the help
Michael
Again thank you for the help. With the information you provided me I was quickly able to find a suitable replacement part.Also after seeing the specifics of this device I know why it was giving me what I assumed at the time were strange readings.
I found in our spare part inventory a different switch which I did not find int the catalog you provided I would like to ask for help again and hope I'm not overstaying my welcome like a bad house guest.
Thanks again
Michael
2nd switch
B.P. _38170 Seyssinet
DPA 4
10/30V=
Good Afternoon , I am looking for Industrial Ink Jet Printers that mark cases of product with Bar Codes , Lot Numbers , etc. I'm looking to...
2,030
hello all .. this might be Out of the topic but just hope some had come thru or know something about it . looking for supplier for 500L SEED...
1,454
Has anyone used one of these protocol converters like the Redlion or others to get data from Frick RS485 or Ethernet units? Customer has both...
2,894
I have a customer with a system that has an open controller in an Allenbradley SLC rack. It appears to be a computer that is sitting in the first...
1,636
Where can I find information about the DH-485 hardware requirments like normal voltage outputs for the network between two 1747-AIC unit and from...
2,356
