Looking for software to program AEG Modicon Micro with 110-612-00
roxley
Apr 2006
Boston
20
Hi All,
I'm trying to program a Modicon Micro 110 CPU 612 00 PLC and I can't find the right software, or any software, that will even open a com port, never mind actually programming. I've looked for Imodsoft: can't find it
Can anyone help me with this?
Thanks!
The older DOS taylor and modsoft software directly controlled the COM port. Windoze won't let software have direct access to the serial port so even if you run the software in compatability mode you may have problems. I have successfully used DOSBOX with some of the older software but I haven't used it with Modsoft. You may want to consider that as an option.
It only needs to directly control the comm port if rtu mode is used (this mode relies on precise timing) if you are able to use ascii mode you will not have a problem. I use ProworxPlus under XP using this method
Thanks to all who replied, but I've decided to stay with idec PLC's and sell off my Modicon Micro's. I have 5 for sale if anyone is interested.
Again, thanks for all your support and mentoring wisdom!
Anybody able to point me in the right direction to get programming software/manuals for one of these? Eurotherm SSD LINK L5207-2-00. Thank, Jack
2,438
Would anyone know what software is needed to program a SAIA PCD1 controller? Or know where to find it online?
166
Hi, I desperately need to access a General Electric (aka "GE") wind turbine inverter control board (in a wind turbine) via the "GE control...
1,397
I am looking for Logicmaster software. I have a GE Fanuc 90-30 PLC that was loaded using Logicmaster. Logicmaster is the only software that will...
2,110
Hi guys, I am john and I have finished my graduation in software field and currently looking to kick start my professional career. At present I...
1,781
