Looking for suitable RS-232 to RS-485 adapter
rguimond
Jul 2009
Escuminac
666
I have a bunch (20+) of Yaskawa GS5 inverters and would like to connect them to our modbus network. Unfortunately, they only have native RS-232 capability. $200 each for CM-085 adapters is a bit prohibitive.
Most of the "cheap" adapters i can find on E-bay have 9-pin serial connectors and i need something I can hardwire. I did find a Kantech VC-485 which should work. Does anyone have experience with the Kantech device?
Had nothing but good luck with B&B Electric.
http://www.bb-elec.com/Home.aspx
One thing we do sometimes is buy a DB9 serial cable and cut it in half for the hardwired end. If all your DB9's are Female, you can order Male/Male cables and get 2 pre-wired connectors from each. The wires are sometimes very small gauge so I wouldn't try a long run or something that moves but for a short stationary hop, not a bad way to go.
We've had good luck with these guys for serial cables:
http://www.cablestogo.com/
Good Luck
Hello,
I use ADAM 4521-A Converter, maybe this is a solution. Here have you a link:
http://gridconnect.com/addressable-rs422-485-to-rs232-converter-adam-4521-a.html
Best regards,
Robin
Im looking to replace a retroreflective Photoeye with a throughbeam or light curtain. The retroreflective eye is causing some issues with...
4,183
Greetings. I currently have several systems in operation mainly using Aromat PLCs and Beijer Exter HMIs. The HMIs email to VText.com to send us...
38
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
493
191
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
266
