Losing connection to TwinCAT in Visual Studio
Sep 2019
Here
I have an odd problem that consumes a lot of precious time. I will often lose contact with the TwinCAT System Service, and be completely unable to control the soft PLC.
After setting TwinCAT to config mode, downloading my new code and logging on to run, the fans of my PC spin up and I can't stop the PLC process.
See the screenshots below, where the alternatives are greyed out.
Are there any way to stop such a runaway process? The only thing that seems to work is rebooting the PC.. Right clicking on the TwinCAT UI and trying to set it to Start/Stop or Config does nothing at all. It should be noted that the UI icon is green, while the icon in Visual Studio is red.
I had exactly similar problem while ago. Problem disappeared when I updated my laptop network card driver.
Hello, I'm trying to close an on top display using global connections. I'm using FTView ver 11.0. I have watched You tube videos and read many...
2,392
My PVP7 (performance) Hmi keeps losing connection to plc. Plc is L33ER v31.011, Switch is Stratix 5400, also on the network are two EIP leak test...
1,743
We have some PowerFlex 40 VFDs with 22-COMM-E adapters communicating with an L61 ControlLogix over Ethernet through Cisco Network Switches that...
4,644
Good day all. I am having a problem with a client node GUI losing track of data from the server. It is just a small workgroup that contains a...
5,251
I am using a VM for my Rockwell software, and have been having a weird issue. Essentially, I configure my devices in RSLinx using the Ethernet...
5,857
