low flow alarm
sheirj
Nov 2005
Wisconsin
52
I need to find a way to alarm when a small piston type metering pump has zero flow. The gpm is around .01. My available card in a very full plc is a 120v input. I have found some switches but I think the pulsing will make the switch cycle. Does anyone have like equipment in there plant or any other ideas? I thought about capacitance sensor but the line never goes empty.
Thanks in advance
Sheirj
How far apart do you see the pulses?. You still may be able to use this switch you referred to.
Besides, on a PD pump why wait til the flow is Zero? Wouldn't you want to stop it before Zero?
Have you ever checked out the company by the name of Dwyer. They have all kinds stuff like that but I don't know if it will go that small.
I would think that you could use a pressure switch on the feed line, this would tell you when the pump is stroking. Run the pressure switch to the PLC. If you have no pressure pulse within a given amount of time, you have no flow. I would check to see what happens when the pump loses prime, I would think that the feed line wouldn’t have as much pressure during the stroke as it would if the pump is primed.
Thanks for the replies.
Rube, I'm not a pump guy so maybe I didn't describe the pump properly but I understand what you mean. This pump is a metering pump so it's ok to let it go dry. The pulses are about three seconds apart. I'm just think the switch will pulse as well.
hipoint, I have checked out dwyer. I am thinking if I get one set low enough it won't cycle or maybe I can put a timer in the logic say switch off for 3sec then alarm.
Tark, That is what I think I will try is to put it into the feedline and put a timer in the logic.
Thanks, It will be next week or so before I get to it.
I used the same type of pump for vitamins..It's a stroking pump and gives low flow..i will check the name of the sensor we used..We programmed with a 5 second time delay..No pulse for over 5 seconds shut down and flash a light..
Will track the info down for you tommorow..
D
I found an older thread about fixing this issue, but the link to the technote was dead. I'm running InTouch 2014R2 with SQL 2012. When I try and...
1,321
I am receiving attached error on Wonderware 2012R2 Alarm Database.As per InSource, the solution is Tech Alert 118 but its no longer available on...
3,580
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
212
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
183
Has anyone installed Hp laserjet pro 4203 to OMNI 3000 or 6000 via ethernet..Is there a specific Config? I have a problem..Please advise
73
