M340 IP connection
edumarquez
Jun 2016
Águeda
Hi all,
I have to do an intervention in a factory, and they use schneider M340... i never work whith schneider plc's... so how can i get the IP of the PLC when i´m there, in order to establish an TCPIP connection and upload the plc software?!
Schneider products equipped with an Ethernet port have a default IP address which is derived from its MAC address (unique identifier assigned by the manufacturer).
For an M340 PLC, the default IP address format is 84.x.x.x where:
84 = fixed value
x.x.x = the last three fields of the default IP address.
These last three fields are obtained by converting the last three hexadecimal bytes from the MAC address into decimal values.
Example:
The MAC address for an M340 PLC is 000053121AC4.
The conversion of the last three bytes from the MAC address into decimal values gives:
16#12=10#18
16#1A=10#26
16#C4=10#196
Therefore, the default IP address for this M340 PLC is 84.18.26.196.
Notes:
For more information on this subject, refer to the Unity Pro online help (Deriving IP parameters from a MAC address).
The MAC address is marked on the module.
The method for deriving the IP address of BMXNOE0100 and BMXNOE0110 modules is exactly the same:
Was this helpful?
Hi everyone! I am newbie here so be kind) I have some m340 plcs in one network and one TSX quantum, that reads data from them via io scanning...
1,465
Hello, M340 plc. 3 standalone citect scada applications. Connection type (OFS server). Same application on all 3 stations and multiple logins to...
1,856
Good Afternoon All, I'm trying to connect to a M340 for testing purposes, and I seem to be having a weird issue, I can connect and download the...
1,319
Hello everybody, I have done a project with Unity Pro and SCADA with Vijeo Citect. Firstly, I simulated the project with Unity Simulator, and the...
4,345
Hi, I download my target with USB cable and everything is ok but I am trying to connect a plc and HMI through internet switch but something is...
2,611
