M340 to PanelView
IsaacC
Jul 2010
Minnesota
I'm trying to get an M340 PLC, specifically the BMXP341000, to communicate with an Allen-Bradley PV+ 1000. The only port on the M340 is a modbus RJ45 female that I know is used for Modbus serial connections. I'm assuming the HMI can load a Kepware driver for Modbus communication, but does anyone know what the cable would be between the two?
I have an RJ45 male to DB9 Male cable that is "straight through", shown below.
I could try opening this up but I'm still not sure what pins go where. Tried to find pinouts of the Modbus port on the M340 and didn't find anything, maybe I was looking in the wrong places, ha. Thanks.
Pin Configuration of M340 port ( RJ 45 ) is attached. Here RX and TX will be Pin 1 & 2. Most probably PV+ serial port used RX as pin 2 and TX as pin 3. So your cable should be
RJ 45 D shell 9 pin
1 ---------> 3
2 ---------> 2
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
240
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
141
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
317
I'm using M340 (Schneider Electric) as modbus master. It works fine but if there is a disconnection with the slave, it stops working even after...
429
Hello, I am trying to send sms messages using SR2MOD03 with an M340 and can't find anything related to it on the internet, can you please help...
206
