Machine Manuals
nmurray
Apr 2014
USA
90
What software do you guys use to make equipment manuals?
I want something I can import the pdf of electrical / mechanical drawings all into a single pdf along with our typical manual.
I'm just having a hard time finding something that works and works well.
for the manual - I use word.
for the parts manuals, I give the customer the brand name catalog - no joke, that was a requirement until I delivered 4 ft of books per machine. now he lets us copy the parts pages and we have a parts manual.
for the drawings, we use autocad.
james
I did not know this. How ?
Open your CAD drawing, print to PDF, and when it prompts you to save the file choose (.JPG)
It is then saved as essentially a picture.
Insert a picture into word.
Same goes with excel. But i normally just copy the cells i want to use and paste in word, then resize as needed.
hmm.. there are a few solutions available for quite a while, like cutepdf and pdfcreator.
orrr.. did you mean you didn't know you could import them in word?
pff things are getting easier and easier. I know I have been busy converting HPGL output from AutoCAD to something readable for word perfect (wpg?)
later on for word... cad2emf? it was a bit of hacking to get a pretty manual together. I hate those scanned pictures.
I admire though the old manuals with hand drawn pics
Thanks, i thought you may have found a way to actually "import" a pdf doc directly into word
It depends on what the customer wants the documentation in as most now want it in electronic form as well a printed copies, I don't think it really matters as nearly everything can be printed to PDF for printed documents, however some customers like particular formats but docs can often be converted to different formats, drawings can be exported to DXF so most drawing packages can import them and some customers like documents they can edit for example drawings so any modifications can be updated. And before people start peppering this post with "Oh we don't like the customer to modify they don't know what they are doing", many customers of mine have quite competent engineers if they B**** it up then that's their fault They can then come back to me to put it right.
The caveat with this is if the resolution isn't high enough, it's worthless. It looks good enough in page view but you find that you zoom in only to see that the image is blurry.
To be honest we generally just use Word for the manual and provide the schematics and drawings separately.
Actually, if you have a new enough version of MSWord you can.
Go to File -> Open -> Browse. When you select the correct directory both PDF and Word files will show up. Make sure the drop-down box to the right of the file name entry is on "All Word Files" or "All Files". Click on the PDF of choice, and Word will attempt to import the file, including graphics.
Results vary from almost perfect to pure ****, depending on the characteristics of the PDF. I do this all the time using MSWord 2016.
Try it with your version - the worst that happens is you have a **** file!
If you print using Adobe PDF you can print your drawings as "B" size pdfs (11"x17"). Then you can open your manual in Adobe, got to the "Document" tab, and insert the drawings into the PDF file anywhere you want. That gives better resolution than a JPEG. If you printed the PDF as a B it will stay a B in the manual. Or, you can print the PDF as 8-1/2x11 (A) and have all the same page size when you insert.
Thanks Tom.
I do the same. Schematics and drawing separate.
Hello Everybody Anybody knows where I can get this version of SoMachine? The new machine expert version won't open my project saying there is a...
39
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
109
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
105
Hello, I am still new to PLC programming and I just got this job two year out of school so I don’t remember much. I was given a task were I have...
169
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
112
