Machine uptime and downtime tracking
jtashaffer
Aug 2009
KY
415
I am using studio 5000 and Compactlogix controllers. I am wanting to track uptime and downtime on 3 different machines. It is setup already but it is done using GSV instructions. There seems to be issues with the setup and doesn't appear to be accurate. I want to try to setup it with out using this GSV instructions and use timers. The original setup was done by a outside source. How do you guys track uptime and downtime accurately.
2-12hr shifts (24hrs). Uptime and downtime per 12 shift. As far as the GSV instructions the processor is getting minor error from this setup. I want to have a setup more simplified to track uptime and downtime and see if I can stop the processor minor errors.
We also have two 12 hour shifts. I use two retentive timer with a 60000 preset time. On completion it increments an uptime/downtime minutes counter. Very simple and allows me to view/edit the info if needed.
I use the information to send out shift reports to the managers. The runtime + downtime minutes is 718 minutes (2 minutes short of 12 hours) due to the timers not completing. It's a general report and doesn't need to be more accurate than that.
Only have a minute until lunch is over so I just wrote out the ladder logic. In studio 5000 just copy paste the below lines and define the variables.
downtime:
BST XIO Machine_is_Running RTO downtime_timer 60000 0 NXB XIC downtime_timer.DN ADD downtime_min 1 downtime_min RES downtime_timer BND
uptime:
BST XIC Machine_is_Running RTO uptime_timer 60000 0 NXB XIC uptime_timer.DN ADD uptime_min 1 uptime_min RES uptime_timer BND
Hello Everybody Anybody knows where I can get this version of SoMachine? The new machine expert version won't open my project saying there is a...
39
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
113
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
108
Hello, I am still new to PLC programming and I just got this job two year out of school so I don’t remember much. I was given a task were I have...
172
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
112
