Magelis XBTF and SLC500
Christoff84
Jun 2006
Cambridge, ON
407
Hello,
I've recently gotten a Magelis XBTF and a few SLC 5/04 PLCs I've looked around for how to network these together but haven't come up with much.
I know the Magelis has an RS-232C output and the PLC has DH-485 capability as well as DH+.
My question is can I network the HMI directly to the PLC processor via the DH485 port and have it accessable by other PLCs on the DH+ network or do I need something like a scanner/modbus card to interface these together using File Copies?
I've used these with direct connection from the 25pin on the Magelis to the DF1 port on SLC5/04 but I don't think they have any type of pass-through capability unless you did messaging from PLC to PLC, and I know they have the ability to do DH485 and DH+ probably with an optional comm card.
One method is connect the PLCs using DH485 and connect the HMI via serial to one of those PLCs then setup data registers in that PLC to send/recieve the necessary data between the PLC's.
The Magelis has a programming/print port and the RS232/485 port so you could be able to access it and the SLC's at the same time depending on adapters and ports available. Here is a manual for the XBT-F; http://ecatalog.squared.com/pubs/Machine%20Control/Operator%20Stations/Message%20Display%20Terminals/XBT/XBT-X000US.pdf
Dear Experts, I have been looking for help from the Schneider website on how to transfer my application to a Magelis display but I think many of...
1,329
Hey guys i need some help here as this is my first time to connect an XBTF HMI to a Modicon TSX Micro PLC and its just driving me nuts.. I got...
6,443
Being fairly new to the PLC world this may sound like funny question, but I was wondered is it possible to use Magelis HMI screen, which is...
3,319
I am having trouble running the application throught my PLC, tm221me32tk with magelis HMIGTO6310 I have prepared the plc programme, also created...
115
Good morning friends. . We are having a problem with one of our machines that have two HMI consoles connected to the same network. They have...
1,125
