Magelis XBTN 400(2)
plcsoftvsd
Sep 2007
23 15 13.2 N 77 27 28.75 e
132
Hi Gurus,
I am usin Magelis for monitoring/ Controlling a process.
Monitoring the inputs/outputs was easy,..converted them to %MW and used 40000x..
But if i have to use Magelis to start a sequence or stop let us say % I0.1 and also i want to change a setpoint say.. %Mw0
How do i start a sequence which normally starts by a pushbutton ( say %i0.1)..or in other words...what are set of instructions to be written in XBT L 1000 software ( Magelis) to start a sequence..?
thanks
plcsoftvsd
You can ‘t use inputs in the XBTL-1000 software.
So you have to add a bit instruction (eg. %M10 of %MW10:X10) in parallel with %I0.1 in your plc program, and use this bit in your XBTN program to trigger the wanted action.
urgent
I have a bit instruction (eg. %M10 of %MW10:X10) in parallel with %I0.1 in my plc program, and use this bit in my XBTN program to trigger the wanted action
my question
is it enough for send my command to plc and my plc accept this command?
plcsoftvsd said:
Hi Gurus,
thanks
plcsoftvsd
You will have a start button on the xbt which will be in parallel to the push button in your plc software. Use your plc for control not the xbt.
I am having trouble running the application throught my PLC, tm221me32tk with magelis HMIGTO6310 I have prepared the plc programme, also created...
109
Good morning friends. . We are having a problem with one of our machines that have two HMI consoles connected to the same network. They have...
1,120
I am looking at a bakery oven that has been dismantled and in storage for unknown time, it was manufactured in 2012 so not that old. my gig is to...
3,619
Any regular users of the magelis range? If so, anyone have a slick way to do a common popup with a rockwell UDT? My current approach is to just...
1,653
We're a second hand machinery merchant. We've just had a machine arrive that has a Schneider Twido TWDLCAA24DRF PLC and a Magelis XBT-R411 HMI...
2,400
