Magnetic bar coding and sonics
John Morris
Sep 2015
San Antonio
689
HELLO ALL
JUST THROWING THIS OUT AS PART OF MY "SEARCH EVERY WHERE AND LOOK UNDER EVERY ROCK FOR AN ANSWER" ROUTINE.
SITUATION: PROCESSING BASKETS OF COMPONENTS THRU CLEANING TANKS, ONE OF WHICH USES ULTRA SONICS. DATA LOGGING USING MAGNETIC BAR CODES ON THE BASKETS TO TRACK. (UNDER THE IMPRESSION ULTRA SONICS WILL EAT RADIO TAGS)
HAS ANYONE HAD EXPERIENCE WITH MAGNETIC BAR CODING WHILE PROCESSING ULTRA SONIC BATHS.
DOES THE ULTRA SONICS INTERFERE WITH THE MAGNETIC STRIPS AS TO FRAG OR DISTORT MAGNETIC CODING.
NOT SURE i POSED THIS QUESTION COMPLETELY CORRECT BUT ANY HELP OR A POINT IN A DIRECTION WOULD BE APPRECIATED.
THANK YOU FOR YOUR TIME AND ATTENTION.
You might want to dig into the RFID a bit more. There are tags available that can survive almost anything. I suspect that they would last a lot longer than magnetics.
If it turns out the testing hasn't been done, ask/pay a supplier to do the testing for you and then add it to the spec.
Or, pay an independent testing company to design and certify a test for it. Maybe something like 0 magnetic degradation after 3 months of high ultrasonic exposure.
It a good idea.
Contacted three mag strip suppliers and was told its such a small niche in the market that it hasn't been/wouldn't be considered. Not sure i could swing an r&d cost
we've done data logging under these conditions but the input was manual.
We'll press on and find a solution.
I am considering using a "magnetic cable tie mount" like this one: https://www.grainger.com/product/MAG-MATE-Magnet-with-Zip-Tie-Holder-49M018 It...
82
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
144
I have a murr IMPACT67 Pro E DIO8 IOL8 M12L 5P and a Magnetic sensor MSA213K. connected to a L18. encoder is connected to port 0 and I am...
628
Hi Experts, I am reading the engine speed from a magnetic pickup - magentic pickup is placed near the flywheel and when a teeth crosses it...
19
6,134
I need something to vary the speed of a magnetic vibrator. It's 120vac Single Phase, 60HZ, 0.5amp. Need something I could give a 4-20ma signal...
2,270
