Main contactor in front of Sinamics infeed module S120
Plc_User
Dec 2005
Belgium
317
So far I have always seen a main contactor in front of a Sinamics infeed module of S120. Is this really necessary, since safety category 3 can be accomplished with the integrated safety of the drives. If it should be realy necessary, when should you start then the infeed module (and activate the main contactor) : all the time (f.i. when 24V is active in the cabinet, or when the plc is in run) or should you only activate the infeed if the drives have to be activated and shut down the infeed if the drives are not activated anymore.
i have no experience with sinamics, but with masterdrives. but i learned that it is better to use a contactor to supply any drive. you cannot always trust the electronics to cut power off in case of a problem. this contactor should be always active except for the following two cases: either the drive has generated a fault and can no longer control the motor. or the emergency safety relay delayed output is off (you should use one with this feature).
330
Hello Everyone- I'm working on a new network deployment of AssetCentre and I am not able to authenticate with the application using our...
411
TLDR: I try to establish the OPC communication between Kepware OPC DA Client to ABB 800xA OPC DA Server. In the Kepware OPC quick client of poll...
866
Main rack contained power supply 140cps52400 and 140cpu43412A and RIO HEAD 140CRP93100 in addition to another I/o cards . Another remote rack...
1,872
Hi Installing Plant Scada 2020 on domain Encountering heaps of issues. Completed fresh server install and domain. Noticed some of the...
1,747
