Make shift register with Zelio Soft 2 for Smart Relay Zelio Logic.
angelromerojm
Sep 2020
Carabobo
Good afternoon colleagues, a pleasure to greet you.
In this opportunity I require some help from you.
I am trying to make a shift register in the Zelio Soft 2 program for a super basic Zelio Logic, I know that because of how simple this Smart Relay is, it should not require this type of special functions. However, I have done it in LADDER and it works perfectly.
But I want to do it in BDF, which is the other programming language and but I can't get it to work, and my experience with this last programming language is very low, I have tried to translate it simply but no, I can't.
And if you wonder why it should be in BDF if it already works for me in Ladder, it is that in BDF I can communicate between this smart relay with a small Magelis hmi that comes with it.
It is to perform filling in a rotary filler according to container feeding.
It is something similar to this topic:
http://www.plctalk.net/qanda/showthread.php?t=18340
But, unlike the rejection due to poor condition of the container, it is about the detection of containers at the entrance of a rotary filler, and that a few steps later, the filling valve is activated, then: if there is a container, it fills it. If there is no container, it does not fill.
I would be grateful for any advice or help, greetings,
Angel
I am attempting to reject a bottle If the label fails. The rejection works fine at normal line speed but at low speed the rejector fires (air...
35
1,193
Hi guys, I am pretty new when it comes to programming. I am working with CX-Programmer and I am having a problem where I have a sensor on my...
707
Hi all, i have a very slow indexing machine where we are looking to make everything as bulletproof as possible, money is not much of a factor...
3,083
Good morning (EST), I am trying to implement the code below in on an S7-1200. It's barely half a dozen instructions, but I am stuck; I have not...
26
5,738
Hi everyone I am completely new to using shift registers and am a bit stuck, my shift register works as should, it is for an overhead conveyor...
55
15,728
