Making histogram in WinCC
mulderm
Jun 2003
Netherlands
298
Hello,
I known in RSLogix5 you can making a histogram and save it in a text-file.
Is this also possible in WinCC flexible using VB-script?
I want to make a histogram from 6 boolean inputs for 10 sec.
long when I pressed a button and save it in a *.txt or *.csv file on my harddisk using WinCC Runtime.
Any idea to do this?
mulderm
Thank you for the information.
I want to log some inputs and will stored in a file.
I have a mpi-network with a modem(adres:0), plc-300 (adres:2),
and a Touch-panel (adres:3).
So I can make a new WinCC project called "Log" and started
in Runtime on my pc on the mpi-network with example MPI-adres: 5 ?
mulderm
Hello, I want to make a histogram of an input (y-axis) is plotted against time (x-axis). Using OB35 (100 ms), I want use DB1 (boolean, length...
2,601
Hi, I have seen a few post with similar topics and I have tried contacting the authors however I have not had any luck so I am posting this new...
1,024
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,552
Hi all, I have been working on a tool for my company that handles a specific task our company runs into often related to PLC's. This is a tool I...
2,903
Hi, i need to make: 1- A PLC Program on Omron PLC CP2E-N using high speed counter E6C3-AG5B 360P/R 2M(Absolute) ,to Reject bottles on Conveyor...
889
