Hi I am having trouble with a Motion action Move CMD. The drive is not exactly tuned so that is part of the issue but I have a question about the Command position reaching set point. During the move the the actual position follows the command position at a close rate of about .05 inches. When command position reaches he set point my velocity changes from the programmed speed of .005 inches a second to .1 or .15 and oscillates to bring the position in line with the command position.
Is there a way to not have the speed ramp way beyond my programmed move. if not is there a way to limit the magnitude of the velocity after command position reaches set point?
Thanks any help is apreciated I am working on tuning but it has to be by hand because underload the drive must follow closely with 3 other drives
