Manual Addressing a SLC from ControlLogix across DH+
see if this "down and dirty" setup will get you working through the DHRIO - without the ControlNet link ...
it's working OK in my lab right now ...
note that the DHRIO has NOT been added to the I/O Configuration in RSLogix5000 ...
SOLVED! (whew)
The connection information was wrong below the path.
I went into RSLinx (after pulling out my hair) and noticed that the Backplane information did not match the Source Link field.
Seeing my CNB Master had a link ID of 12 in Linx, I put this in, and it works!
Thanks for the help guys! In the manual, source ID is not explained, but after some Google searches, I found other notes about it.
Ron, your suggestion did not work, however, I added my ControlNet card before your 1,9 and it did, shortening the connection path! Bravo!
Right Good !
As for the DHRIO minor error - earlier revisions of DHRIO modules produced a minor error if BOTH ports were set to DH+. Don't know if they fixed it in later Revs.
If you aren't using port B set it to RIO, that may get rid of the minor error.
What is your full path now ? - I still believe the last number should be 1, the DH+ node address of the SLC.
not sure I'm following all of this - but you seem happy - so we're happy too ...
just for anybody who searches this thread in the future, the screen shots that I attached above DO work in my lab - using just a DHRIO which is NOT added to the I/O Configuration - and without using a ControlNet connection between the ControlLogix and the SLC-5/04 chassis ...
party on ...
Ron,
I think, since I'm using ControlNet between my CPU and the remote IO rack that contains the DHRIO card, I had to put my ControlNet card in the path. ?
Anyway, Communication Method is equally critical (in my case, at least). I had to verify the source and destination Links in RS Linx (use Link as a reminder for Linx!)
My Destination Node was easy, node 1 as said in Logix 500 Channel Configuration for DH+
Please see attached. This might only be needed for remote I/O folks, I've read in places that you can leave these links at zero, but not my case.
and the minor recoverable fault is because I'm not using DH channel #2. Can't simply disable it, like on input cards... I can live with that.
Yes, you can live with it, especially since you don't have the DHRIO module in your I/O Configuration.
But if you did, the minor fault would set your I/O light flashing on the controller, which would make it a useless diagnostic.
As I said before, you can "cure" the somewhat false error by setting the unused channel to RIO mode.
And a further thought is that I'm not convinced you need a routing table in the DHRIO modules at all, the MSG path should find your destination.
But if it works as you have it, leave it be.....
Aoa i am working on plc project, i want to address the manual auto switch in plc,how we address the auto/manual switch ?can we use only the...
4,205
Hello Guys, I'm working on Honeywell HC900. I am using the PID block. I have attached the Switch and loop block to it as well. I have attached a...
633
Hi, I'm assisting a friend remotely with a VFD he's planning on buying and looking for a manual before hand to start planning. It's a Vikye. The...
930
This may be a long shot, but would anyone have paperwork on the Nedap 3.5 KW Driver ( Ballast) UV lamp ballast Modbus can communicate with the...
367
Hello all, I have an old machine that utilizes two FEAC PC-116-24 controllers used for position monitoring and output to an OMORM CQM1 PLC. I did...
627
