Maple HMI5104TH Barcode Reading Problems ...
sealyons
May 2014
Westfield, MA
I know this is not directly PLC-related but I'm guessing it's close enough. If it's not, please let me know.
I'm working on an application for a woodworking machine that uses a Maple HMI5104TH graphic HMI and I need to read barcodes. I have a bit of experience with Maple products, but I'm by no means an expert. The 5000-series Maples supposedly have firmware that will allow barcode reading via USB but I'm having no luck getting it to work with their barcode demo (modified to use a USB scanner instead of RS-232). The barcode communication driver is setup as a type of PLC in Maple and the configuration appears to be pretty straight-forward. It supports a single FLAG for SCAN COMPLETE and a set of REGISTERS that should contain the scanned code. I believe my scanner doesn't use a start-code and has a CR/LF termination. I've tried lots of comm settings in the driver but have not had any luck yet.
I'm currently using a cheap USB eBay scanner for testing. The program compiles & downloads fine but does not register any scans (FLAG not set & REGISTERS empty). Has anyone played with any of this and got it to work with a USB scanner? Any comments on types of scanners that appear to work the best with Maple? Is there any configuration setup that has to be done on the USB ports or anywhere else to get this to work? Any suggestions are appreciated.
Greetings all, I have an 5104TH HMI set up to log data to an SD card on an interval. It's hooked up to the network with a certain IP. We are...
4,177
hello, I have a Maple Systems HMI5103L currently programed and running in conjunction with a AB 2080-LC50-24QWB. everything works fine data is...
728
I've been tasked with modifying a current hmi program for the addition being added to the cell (auto/manual ,I/O ,Status). When I try to upload...
430
Hi. We're refurbishing a used machine with a Maple HMI5070TH HMI. I'm trying to establish the log-in details. There are four users; operator...
336
Hello everyone, I have a machine I'm working on that has a Maple HMI5070NLv2 and a Micrologix processor. I have the PLC running on RS500 emulate...
1,436
