MAPware 7000 - project won't open
Saulo35
Jan 2012
Port Coquitlam, BC
112
Today, after working a few hours on a MAPware 7000 project (runs on a Maple Systems HMC3102A-M HMI+PLC), I saved it and closed it. When I tried to open it again, I got the following errors:
Information: Invalid File Extension
Error: Selected project has incorrect data, hence failed to open project.
Any suggestions?
The only changes worth mentioning were the addition of some pictures as .JPEG files, which MAPware expanded into large (a few MBytes) .BMP files.
Thank you
So this is a weird one. I'm using Maple System's HMC2043M-A HMI/PLC controller, and after 15 minutes it seemed as if the HMI became unresponsive...
760
Hi, When simulating my project, calling a numeric keypad causes MAPware 7000 to slow down to a crawl, and the keypad does not accept keys...
1,173
I have 3 new PowerFlex 7000 VFD's. Rockwell was out to do some checking before startup. These are part of a larger electrical project. I gave the...
332
Just purchased Studio5000 and have it installed, will be connecting to 3 brand new Powerflex 7000 VFDs. In setting up the module, how can I tell...
769
I have a contractor at my water plant installing 3 brand new Powerflex 7000 VFD's for my High Service pumps. I would like to control these via...
1,011
