Master control relay
willie_j70
Jan 2005
Does anyone know if you can reset a counter with the reset inside the boundaries of a master control relay, if the MCR is de-energized, leaving the associated rungs without control logic? This s a project I'm doing for school, and my instructor was not vailable when I needed an answer to this question. If you feel like calling, give me a buzz. 708.758.1299
Thanks,
Willie J:beer:
Ummmm.... We'd probably need to know which brand of plc you're using to give a firm answer. Let us know, and we'll take a stab at answering the question.
Let's see if I understand correctly....
You have a counter which is outside(or inside) of the mcr zone....
And a res instruction inside the mcr zone.....
And you want to know if you toggle the reset command when the mcr is disabled, will the counter will still reset?
If I'm understanding the question correctly, the answer is no. When the mcr is deactivated, the res instruction will not reset the associated counter until the mcr is activated.
Here is a picture of what I'm talking about, from a running processor...
This is a seven year old thread and not related to your question. You should start a new thread. The MCR in this case is a software instruction inside an AB PLC. It isn't a physical master control relay. What is your application and what are your questions?
Master Control Relay can mean different things to different individuals. For the context of this discussion, I am speaking of a device that is...
5,808
I'm reading the book Programmable Logic Controllers published by Newnes. I'm finding the section on Master Control Relays a little confusing. I...
2,545
Just a quick question...I know that a hardwired master control relay should be present and you should never rely on one programmed into a PLC...
8,640
I have to start out by saying I am not a PLC programmer and I have basic programming skills but mainly use software as a troubleshooting tool. I...
138
My tutor asked me for this small project: using S7-200 control MM440 with PROFIBUS. Because S7-200 with PROFIBUS module EM277 can only be PROFIBUS...
2,982
