Master-Master or Signal booster or etc?
MZohaib92
Feb 2017
Pakistan
Hello guys,
I am using Fatek PLC's to communicate with each other as a Master & Slave through zigbee which is connected through RS485. And I succeed. But the issue is that I have to communicate each other at a distance of about 2km where zigbee out of range to each other.
I am bit confused here;
1) whether I use RF booster? Does it work?
2) Should I introduce extra PLC as a repeater between master slave? But this(extra added) PLC repeater also become as a master(Master Repeater).or any idea?
Most important I can using Fatek Protocol or Modbus RTU or Modbus ASCII prootcol.
But sir in your first link rs485 repeater but in rf signal how can I use repeater of rs485?
Can I use rf booster or repeater ?
Does rf booster boost multiple zigbee's signal at different end or one booster only boost single rf signal please guide me
I am new to this forum and coming here as a novice to PLC work and signal However, my questions here hopefully won’t pertain to PLC programming...
2,329
117
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
64
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
65
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
252
