I am sure thinking about this that it would be easy to build in a little key token system , the master generates a random number sequence and each slave cyclically replies on by one to each pole , the reply is based on a simple algorithm , you can use divide by 4 or nine , there are many ways to do this , OK , so it slows up band width , but it would take a long time to crack it without the code - OK , you cant stop the hack , but you can detect it and catch the bugger - he can't be too far away .
PS , you are a radio guy , surely you can triangulate him , might not get him the first time , but you will the second , he is bound to use the same place - he must drive a 7.5 tonne van , radio , antenna , PLC , power supplies etc?
Something isn't right about this ???!!!...
