Masterclock with Saia and wonderware
RobinH
Jun 2012
Trondheim
54
Im using Saia PLC.
I collect date and time from a masterclock over NMEA 0183 to the PLC. Wonderware intouch picks up this date and time from OPC server.
I want to present the date and time in wonderware intouch and also be able to adjust date and time from intouch. I also need to synchronize date and time to other PC's running wonderware intouch.
Does anyone have a good solution?
Is it possible to set the PC time and date from wonderware intouch or is it just possible to get the PC time and date?
Best regards
I would not recommend setting time from a view station. Intouch and wonderware software relies on a Time synchronization for proper communication. I would suggest linking all the machines to a time server.
Would anyone know what software is needed to program a SAIA PCD1 controller? Or know where to find it online?
175
Questions about an old SAIA PLC type PLC is PCD4 - board RS422 (PCD7.F110) We sold a HMI to replace one but our HMI doesn´t communicate with the...
1,095
Hi there. I am trying to read time of day from a Modbus register in SAIA PCD3 however I have limited data about the point. It should be read as...
2,421
Good morning. I have SAIA PCD4 PLC system (kindly see the attached photo). I need to upload the program to be a backup in case of any...
3,711
hi, i have a machine with SAIA model number PCD2.M5540. Recently i am facing issue regarding the run and stop mode. i tried setting the plc to...
1,842
