Math function problem ge fanuc 90 30
Apr 2011
Manila, Philippines
295
GOOD DAY:
we have problems regarding math functions DIV INT dont do any calculations, all parameters are met.
we do it like this:
from function block "CSS1"
we get the variables "SET_SPEED_K8" (%R00708)(word)
then we use it on the DIV_INT as dividend.
8260 as divisor.
at start "SET_SPEED_K8" has a value of 15000
so we expect to have a quotient of 1 (since this is in INT form)
but there is no qoutient at all.
we also try to convert it from INT to REAL then use DIV_REAL but still nothing happened..
the variables "SET_SPEED_K8" are originally from CSS1 LD block.,
the math functions wherein SET_SPEED_K8 were used are located in "CSS2" a new LD block.. does math function requires it input to be in same LD block?? thank you.
thanks!!!:eek:
I am working with plc5. I am using the CPT function but getting errors. The level of the silo is inputed at F51:031. The silo cuft is 3393 with...
1,611
Hi, it's me again asking for help here to make me understand more on PLC. I've been reading about the MATH function and MOV function, yet I can't...
2,563
I am using Intellution's Fix32 7.0 HMI and was wondering whether anyone can help me in getting additional mathematical blocks as options on...
4,139
I have an expression in a structured text routine of a Logix controller that looks more or less like the following: ResultInteger := Integer1 *...
435
This application has a motor with encoder feedback that drives a linear actuator that moves in/out, and is at roughly 45 degs from horiz. As the...
19
1,404
