Math problem
delatorre
Jun 2002
Tonaya, Jalisco
20
Hi all,
I have a problem in an equation, in example the instruction is:
LD K100 then SUB V3101 (45) then MUL K2487 then OUT V3600.
In other words in the final result of the equation I´m getting other value (3254) diferent of the I´m expecting (136785)
Could somebody direct me please?
I appreciate all your help.
Your product is a double word (more then 4 digits) and will reside in V3600 and V3601.
You will need to use all double word instructions.
MATH PROBLEM
THANK YOU,
NOW, THE ONLY THING IS THAT I´M MISSING THE FIRST TWO NUMBERS.
THE LAST FOUR NUMBERS ARE CORRECT NOW. (IN THE PRODUCT)
REGARDS
I am stuck on what is likely a misunderstanding of how Omron handles data versus Rockwell. I need to scale an analog input to monitor the...
1,540
I'm not at tech ed this year (:mad:) but a coworker shot me this math problem they are asking as part of the experience. Anyone wanna take a crack...
3,220
RSLogix 5000 V24 1756-L72 Trying to figure out the best way to solve this problem. TCF = e ˄ 1100(1/298 - 1/T) Where T = °C + 273.15 TCF...
16
3,910
Hi, I need a formula to convert a Speed input in a certain range to a time output range, problem is that the time is from high to low value...
2,093
I was working on a project and ran into a problem that seemed very simple at first, but became quite a challenge to implement in RSLogix 500...
16
5,591
