matrikon modbus opc server
diat150
Mar 2006
Louisiana
1,474
anybody have experience with matrikon opc server products? I am looking at using one for a huge project that will have approximately 500 rtu's and about 25k total data points. Just wondering if someone has used matrikon on a large project like this. Id hate to find out mid project that it doesnt react well to that many tags! Ill only be polling each device approximately every 15-30 minutes.
Ill probably try and use the high end OPC-UA modbus server.
diat150,
You should have no problem with that especially if you are going to poll each device every 15 min. Just a heads up, if the Modbus network is a little unreliable, noisy, or slow, I suggest looking at the SCADA Modbus version.
Hope this is helpful.
Wassim Daoud
Global Solutions Architect
www.MatrikonOPC.com
HELLO, it a kind straight and forward question, i have one pc, installed with pcs7 version 8.0 , i dont have any other hardware but a lan card...
1,491
Hello, Does InTouch got an OPC client? Or do I need to install a OPC client to be able to communicate with an Matrikon OPC Server? Regards Raffe
2,055
Hi, Can the FT Historian SE catch and store data from an OPC Server like Matrikon? If so, Would the FT Historian take the timestamps directly...
2,880
Hello Guys, i am newbie in plc devices, i need some help and advices. i use Factorytalk Historian on my side, i need to retrieve data from OPC...
1,583
Downloaded from the matrikon portal. I wonder, is it a trial or what?:hmmm: Currently im not having access to my plcs so unable to try it...
2,491
