Max. Number of Panels on a CPU 31x-2 PN/DP
Aug 2005
Hasselt
60
Hi all,
We're planning a project that uses up 20 (maybe more in the future) Panels - TP177 4" Color PN/DP. We'd like to connect them all to 1 controller (S7-31x or WinAC), using profinet for communication with the PLC.
Looking at the PLC specs, there are several types of communications functions that all have a different number of max. connections.
eg. CPU 315-2 PN/DP
- Open IE - Max. Connections: 8 (NA for Profinet)
- Number of usable OP Connection: 15
- Profinet CBA: NA for TP177B
- 2nd Interface as Profinet IO Controller - Max. Connectable IO Devices: 128
Is it possible to connect up to 128 Panels onto this CPU or is it restricted to 8 or 15 Panels?
will an Lean CP card give me the possibility to extend this amount of connectable Panels.
Tx in advance,
HG
"Lean CP card give me the possibility to extend this amount of connectable Panels"
315-2DB CPU gives max 16 (with Lean CP) (15)
317-2DB CPU gives max 32 (with Lean CP) (31)
I think like that.
The mentioned "IO Devices" are Profinet Devices where the CPU is then the Profinet "Controller" (similar to Profibus Slaves and Master). I am not sure that the TP panels can work as IO devices - I doubt it. If they could it would be an awful cludge.
You need a CPU that natively supports the number of OP connections that you require.
If you need lots more panels, then maybe you should look into other kind of solutions, web client panels maybe.
Hi Looking for some advice. I have a project that was developed for an S7-300. In that project I have a number of datablocks which only contain...
2,641
While trying to download produced and consumed tags with a new controller on the same network I get this error: The maximum number of nodes on...
4,282
I'm trying to read a table of 100 floats over ethernet from a ML1400 to an L61 CLX. I find I can only read 58 elements at a time before the MSG...
2,538
Hi everyone. In the manual of AB CompactLogix, it is stated there the number of local expansion modules, max. My question is, are the modules...
4,315
Hi, Does anyone know or can point me to where i can find max number instructions allowed in old 984 architecture PLCs, i hid a "node limit"...
1,474
