peterparch
Guest
P
I am complete novice to the world of PLC programming but am trying to learn.
I have an application that requires using the previous day's average temperature to control the duration that a water valve is opened for operating an irrigation system.
I have downloaded and experimented with the demonstration software from Mitsubishi for their Alpha series PLCs and also browsed through the software and programming manuals. Although the instantaneous temperature can be measured with an analog input port I cannot figure out how, or if, repeated measurements made at different times can be processed to come up with a daily average, maximum or minimum.
Is it possible to do this with the Alpha PLCs ,or any other PLC for that matter?
