Measuring Voltage and Amps on a rectifier
Orn Jonsson
Apr 2002
Boise Idaho
125
Hi all,
I need to bring Volt and Amp signals from a large rectifier into an analog card on a PLC.
Do you know of any devices "shunts", "current transformers", voltage transformers", etc. that can handle 250A and 400V. Preferrably I would like to use 4-20mA signals to the PLC.
This application is for monitoring Volts amd Amps used in a plating process.
Orn,
Hi I working on an assignment and woundering if I' right. A task said why do transducers normally have a output of 4-20mA or a 0-10V, I have most...
1,815
Hi everyone, I don't know much of PLCs but it happened that i need to connect Leuze AMS358i Ethernet laser measurement to Productivity 1000...
1,067
Hello everyone! Firstly I'd like to say that I'm new to this forum and also new to PLC programming world altogether, that said I really would...
27
4,858
I am looking for a way to determine level in a silo. The material is called Perilite which has a very light density. Bulk density could be...
2,753
In our water cooling tank, I've installed and successfully wired up 4 float switches & updated the PLC (big thanks to @parky for that). As a...
46
11,500
