Measuring wet bulb temperature
TConnolly
Apr 2005
Salt Lake City
6,152
I need an instrument that can measure the current wet bulb temperature in an area. I can find all kinds of hand held instruments, but I need something that can be permanently mounted that will provide a signal back to the PLC.
You can get a lot of RH (Relative Humidity) sensors. I'm using one from Omega that has RH and temperature (dry bulb). Given those two parameters you can calculate anything else on the psychrometric chart.
If you search google for psychrometric data or psychrometric charts you will find a number of sites with the appropriate equations.
www.Kele.com
Many Many products to measure just about anything you want in many differant combinations. I have been using these units for a while now without any problems
Dew Point, Enthalpy and Wet Bulb Temp Transmitters.... Check it out. They work very well and very well priced
Hi All, I was with a friend at his factory, manufacturing several CONCRETE PRODUCTS. He wants me to automate the plant's feeding/mixing area...
1,746
Hi everyone, I don't know much of PLCs but it happened that i need to connect Leuze AMS358i Ethernet laser measurement to Productivity 1000...
1,072
Hello everyone! Firstly I'd like to say that I'm new to this forum and also new to PLC programming world altogether, that said I really would...
27
4,885
I am looking for a way to determine level in a silo. The material is called Perilite which has a very light density. Bulk density could be...
2,762
In our water cooling tank, I've installed and successfully wired up 4 float switches & updated the PLC (big thanks to @parky for that). As a...
46
11,543
