Mechatrolink USB Bulkhead Connectors
aiki202
Aug 2007
Pennsylvania
178
Does anyone know of a manufacturer that offers USB 2.0 bulkhead (through panel) couplers that allow the locking tabs to work properly with Mechatrolink-II cables?
Thanks for the tips. I had already searched L-com but didn't see anything. I also already asked our Yaskawa rep and he said they have never used this type of coupler so he couldn't direct me on where to find them. Interesting with how long the Mechatrolink standard has been around as well as arc flash standards (low voltage vs high voltage enclosure areas) that multiple solutions do not exist. Although expensive here is what I found from Digi-Key:
http://www.digikey.com/product-detail/en/EGW.LM.U2A.XPP/1124-1461-ND/3740734
Digi-Key Part Number: 1124-1461-ND
The connector is exposed on both ends thus it allows the locking mechanism to work.
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
183
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
147
please using the usb can i assign any ip address that i want ?
163
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
244
Bonjour, Je n'ai pas de communication modbus RTU vis la configuration ci-dessus. J'ai essayé les deux mode ch1 et ch2 mais rien ne fonctionne...
178
