Melsec F1-20P-E & F2-40M pgm readout ?
theDave2
Aug 2004
Rochester, NY
467
I've got a F1-20P-E hand held programmer attached to a F2-40M PLC and need to read out the program so when this unit goes belly up I can replace it.
The manual for the HHP says to press CLEAR, INSTR, STEP+ to read the elements. When I do this the address readout starts at zero, and only a "K" shows for the instruction and 0 for data, for step 0 to step 150. Got tired of pressing STEP+.
Is there some convention as to where the actual ladder starts ? And how to get there ? When I tried to dial up a step number, the DATA readout changed, not the step #: CLEAR STEP 1 0 0 INSTR did not take me to Step #100, IIRC. Maybe I forgot to press the STEP key.
Tx,
Dave
i suggest that you may have a try as follows:
status:monitor
step----the No_Of the step you want----write----step
Hi, i have a mitsubishi melsec f1-20p porgramer and a mitsubishi melsec f1-20mr plc and I'm wondering if anyone knows how to program a 8ch chase...
6,158
Dear Colleagues, I would like to get user manual for melsec FX-20P-E programming tool, please. Thanks
3,004
I have a F-12R with the little panel that fits on top to program it. Have worked out most simple programming but cannot set the value to a timer...
3,648
I have just started learning to program, the college I attend use siemens. However I have aquired an old mitsubishi F1-20MR PLC and a plug in...
6,318
Hi everyone, I have a small project for an industrial site entry gate system. It's running on an old Melsec PLC, and I have a new Shihlin PLC...
143
