mitsubishi melsec f1-20p
phillip-marks
Oct 2009
devon
Hi, i have a mitsubishi melsec f1-20p porgramer and a mitsubishi melsec f1-20mr plc and I'm wondering if anyone knows how to program a 8ch chase if so can u help
Thanks,
Phill
What is it your after?
That is a very old PLC and clip on programmer.... early 90's
Have you ;lost; the program?
I can remeber you could get a clip on module to program using a laptop, medoc and a sc09 lead but they are like rocking horse droppings
im after a way to program a 8ch light chase (1 after an another)
i learn how to make a count up chase and turn no and off relay's on a timed paten
and at the moment i dont no how to use medoc or sc09 but im trying im onle 16 but i have learnt allot in the last 2 weeks iv had thees
LD 400 (INPUT)
ANI 51
OUT 50
K 1 (THIS IS THE WIT TIME)
LD 50
OUT 51
K1 (THIS IS THE ON TIME)
OUT 450 (OUTPUT)
thats to flash 1 output
Thanks,
Phill
OK
I understand what your trying to do I will have a look tomorrow
Cheers
Hi your question sounds like homework but i will give you some help
Consider a sequence similar to this for each step
Code:
LD X400 (Start)
LD M70  (Step 1)
ANI M71 (Step 2)
ORB
OUT M70 (Step1)
Look at using a PLS instruction to step up the step. Beware..only step up one step a time... experiment for this
[/CODE]
I have a F-12R with the little panel that fits on top to program it. Have worked out most simple programming but cannot set the value to a timer...
3,647
Hello! First time poster and a big PLC newbie so I am looking for some backup here. I have an old Mitsubishi FX-48MR that lost its program...
521
I've worked on one Mitsubishi PLC in the past 40 years. Now, it looks like I get to tackle another one...using GX-WORKS3-C1 software which I...
952
I have been asked to work on a Mitsubishi Melsec FX2N-80MR PLC but have no experience with Mitsubishi at all. The hope is to get online to find...
1,341
I have an 80's PLC, Mitsubishi K2NCPU that needs replacing. Is there a software / cable available to upload and print the current PLC program? Thanks
948
