melsec fx timer question
rphillip
Oct 2002
Hello to the list,
Can anyone give me a brief rundown on the timers used by the Mit. Melsec FX plc? I have a couple of questions in particular:
1} Are there different time values assigned to different groups
of timers,like Siemens uses. For example T1 might be a 1ms timer
while T40 might be a 100ms timer.
2) Is the k value assigned to the timer used as a coefficient of
the timer value. For instance, would k=10 assigned to a 100ms
timer give a 1 second delay?
As I haven't a manual for the FX I'm feeling my way along.
Thanks in advance for any info.
Answers to questions: Yes, and yes...
Do your brain a favor and get the manual... It will make it a WHOLE LOT easier!... :nodi:
Go HERE to download any Mitsubishi manual you need.
In the pull-downs, select "Industrial Automation", "PLC", "PLC-F", then whatever flavor PLC you're using.
beerchug
-Eric
Its been a while since I've worked with a mitsu. In regards to Timer register reads and writes: Does it read the accumulator and write to the...
2,296
S
hi guys, I am new to Melsec Medoc GX Developer. i got a simple question here would anyone who is used to this software could help me on this? I...
7,150
I AM NEW TO USING MITSUBISHI MELSEC FX SERIES PLCS WITH HAND HELD FX20PE PROGRAMMING UNIT. DOES ANYONE KNOW HOW TO PROGRAM A ONESHOT TIMER CIRCUIT?
7,867
Hi everyone, I have a small project for an industrial site entry gate system. It's running on an old Melsec PLC, and I have a new Shihlin PLC...
141
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
387
