Messaging Allen Bradley Via Firewall
Oceansoul
Apr 2010
England
307
I have a need to send some PLC message's from one PLC, controllogix on one network (PLC A - 172.18.239.22) to a PLC 5 on DH+ via a DH+/Ethernet bridge on another network (GW - 172.18.40.112). The is a firewall between the two networks.
Which ports are needed by the MSG instructions that need to be opened in the firewall? I have done some reading, and some things say TCP 2222 or TCP/UDP 44818. Is this all that is required? Do I set up the MSG as usual (i.e. DH+ message CIP path to the DHRIO card then DH+ node address).
You need to open TCP Port 44818 for the MSG instruction to work. Everything else in the message should be unaltered.
TCP Port 2222 is for the old PLC-5E/SLC-5/05 proprietary Allen-Bradley Ethernet network, and there is no UDP involved in a conventional MSG instruction from controller-to-controller.
Hi, We have an existing ControlLogix Processor (Rockwell PLC) and we want to replace it with either an quantum or Unity Processor (Schneider PLC)...
3,209
So I just started digging into this and haven't really found the specifics I'm looking for. Hopefully some of you might be able to point me in the...
1,820
Hi All, Our networks are a mess at our site and are going to be slowly fixedup. In the meantime I have a need for a Control Logix L71 to...
1,936
I have a Micrologix 1400 that needs to read & write a few integers & reals to three SLC5/04's that are connected via DH+ network. To bridge the...
8,230
I am trying to use the new DEM explicit messaging instruction in RSLogix 500. I am using V7.10 software and the SLC L552 is flashed to OS501...
5,309
