Mettler Toledo Safeline RS422 communication
RSibrik
Dec 2015
Tartu
Hi everyone!
I'm trying to set up a communication between s7-1200 and Mettler toledo safeline. I'm sending a service request(request pack count) to the metal detector, no answer. But when i leave the receive line open, and there is an event then i receive event data. I'm not sure what i'm missing here. Is there anyone who has successfully written a program for RS422 communication?
Questions:
Do i need to add external termination to the network?(sofar i've seen no info on this)
The metal detector should answer, when requested or do i have to acknolwledge the event first?
i have high and low lefel protocol manuals and everything seems to be correct but for some reason there is no answer.
I'll attach some screenshots with the data i've got.
Thanks for all your help.
http://www.genemco.com/catalog/pdf/KPSB279safelinemanual.pdf
If you are getting some information in/out then I would start to look at the timing of your communication.
Are you receiving an ACK signal after you send the command?
Thanks for your answer.
I am not receiveing an ack signal after sending a request.
The manual you've posted only describes rs232 comms and not rs422. As i'm receiving data it seems that there is something wrong with my request or with the network on transmit line. I've tried both comms on the metal detector (direct and network). I'll post my port configuration as well.
I can upload the manuals i've got if someone has time to help me out.
Thanks!
Metal detector type: Profile Advantage, Head type: rectangular. Version: F48.1.0.r2
Currently my company has a MT metal detector model V4 that has been down for the better part of a month. The metal detector is giving a F06-5 IO...
3,097
How to do that can any one give me the how to write instructions example
838
I am working on an older system where they are switching out the weigh in motion scale on a conveyor system from an AP Dataweigh to a Mettler...
1,181
Hi everyone, have anyone of you familiar with IND560 weighing scale communicating with micrologic 1400.
3,907
Hi, I have a Mettler Toledo IND780 (AB-RIO) and a SLC5/04 with a 1747-sn RIO Scanner card. I have lost the configuration for the Ind780...
2,225
