Micrlogix 1200 PLC to Printer program
dprathamesh1
Jan 2012
mumbai
dear ,
I am writing a program for 1200 plc for printing using AWA instruction it is printing correctly but data words values are not coming exactly in the same column of header.
how can i do it?
If you need to check program send Email address i will send you.
Prathamesh
ZIP and post your program along with a description of what you expect to see from the printer, and what you actually see from the printer.
My guess is that you are not accounting for numeric length when converting values to strings.
Program
Dear ,
Find herewith attached program & hyper terminal file.
I want all columns will be in line like:-
Cond. Temp. Flow Cond. Temp. Flow
R.Water R.Water R.Water R.Water R.Water R.Water
2 60 2 3 67 2
3 62 2 2 65 2
2 61 3 3 65 3
Prathamesh
Setup: 1762L24BXBR SER C REV B FRN 12 RedLion G306A000 I'm talking to the RedLion DF1 Full Duplex through the Prog/HMI Port on the ML1200. My...
3,394
Hey guys, I am facing a weird issue with a micrologix 1400 series PLC installed in my facility.The IP address of the controller is set to...
1,690
Has anybody used a MLX 1100 with a RSview 32? If so how did you set up the drivers? My counter part is the HMI guy I am the Logix geek. So I...
2,230
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
56
34
