Micro 1400 PID Example
FandA
Aug 2012
Friendswood, Tx
I need a MicroLogix 1400 program example of a single loop PID for back pressure on a meter. If it were a CompactLogix, I would have no problem. Any help would be appreciated.
suggestion: post your existing MLX-1400 file so that we can see the input and output addresses, scaling, etc. ...
also post the equivalent program file that you'd be using for the CompactLogix platform ...
we'll be glad to make the conversion for you ...
note that you'll have to zip your program files before posting them – forum rule ...
Team, I have a micro 1400 and a 1024 encoder using HSC function to control a 0-10Vdc DC Drive (1/3 Hp Motor) for a simple material take up...
2,376
Hi! Last few I've been trying to send message from MicroLogix 1400 to Micro 850. Unfortunately every time I failed :banghead:. Did someone tried...
3,250
Hello, There was a mix up in information on some redeployed equipment and two of the micro 1400's that came in were hooked to 120v when they...
1,991
I am trying to exchange data (N registers) to and from a Control Logix PLC. I am programming the messages in the Control Logix program, to...
2,220
Does the 1100 only have 1 high speed counter, but it can have multiple inputs? And so then the 1400 has 6 HSC and you have a choice of multiple...
1,732
