micro 1400 pv600+ or RS500 and factory talk help
Jeff23spl
Jan 2010
Canada
860
Hello
I would like to know if i did it well or what would be the easiest way if not: To connect my tag database from my RS500 project for a micro 1400 to to factory talk for a pv600+ hmi
The factory talk communication setup verify gave me these result after trying to connect to my RS500 project...Is there any chance to work ?
Warning: Offline tag file and path to non-Logix device assigned.
- Warning: Offline tag file does not have .ACD extension.
- Offline tag file assigned and file found on workstation.
Hello
I could be wrong but I believe that you get those warning messages anytime you create a runtime file for an application that uses a data server that the development cpu isn't currently connected to. As long as your terminal is communicating to your ML1400 then you should be ok.
The "Offline Tag Browsing" feature works with RSLogix 5000 projects (*.ACD) only.
It won't hurt anything, but it won't give you offline access to the data tables in your RSLogix 500 (*.RSS) file either.
You can either Import the data table and symbol database from RSLogix 500 to FactoryTalk View Studio, browse the controller's data tables online, or simply create FactoryTalk Tags and Direct References by typing in the RSLogix 500 data table addresses manually.
Hi! Last few I've been trying to send message from MicroLogix 1400 to Micro 850. Unfortunately every time I failed :banghead:. Did someone tried...
3,227
Hello, There was a mix up in information on some redeployed equipment and two of the micro 1400's that came in were hooked to 120v when they...
1,982
I am trying to exchange data (N registers) to and from a Control Logix PLC. I am programming the messages in the Control Logix program, to...
2,203
Does the 1100 only have 1 high speed counter, but it can have multiple inputs? And so then the 1400 has 6 HSC and you have a choice of multiple...
1,725
Error: "Program in processor has changed causing offline state. Do you want to upload?" RSLogix500 V8.10 Micrologix 1400 Customer wants to add...
2,300
