Micro 1500 and panel veiw cant get online
joeparrish
Nov 2007
owensboro ky
161
Ok I have a micrologic 1500 1746-24bwa with a panelveiw
2711-m3a19L1
Rslinx or rslogics wont comunacate with the plc. I tryed to use a 1761-cbl-pm02 cable (this is the one I use on all other micros and it wont work
But the panel view is pluged in this port and not on the side do I have to do something differnt or do I need a diferent cable
Your PV is DH485 protocol. If the ML1500 and the PV were communicating then the port on your ML1500 is configured for DH485. You will need to use the 1747-PIC/AIC+ driver in RSLinx to talk to your devices. You will need a real serial port to use this driver. Or a 1747-UIC.
The Cat.no. you gave for your ML1500 is incorrect and not complete.
The cable you listed should work for both devices.
2711-m3a19L1
You mention above the port on the side.
On a Micrologix 1500 this is a second serial port, and if you get a null modem cable, with 9 pin to 9 pin D shell conectors, I believe you can use a DF1 RS232 driver to get access.
I am having trouble trying to figure out why the data access toll for the Micro 1500 is not working. I looked at the timers i want to be able to...
653
Hello all, Sorry if this has been discussed previously. I tried searching and found similar problems, but none of them matched our problem. We...
1,498
Does the Old MicroLogix 1500 support Online Editing??? I am being told it did at some point but I think that is wrong...
2,385
Hi there, Just wondering how the Micro Logix 1500 keeps the PLC program when the power is switched off. The one I have, doesn't have a back-up...
2,224
I've got an issue with resetting a counter to 0 on a Micrologix 1500 with a 1769-HSC card. The preset is configured in the IO configuration for 0...
4,864
