Micro Logix 1500
Broadley
Mar 2018
Abroad
Hi there,
Just wondering how the Micro Logix 1500 keeps the PLC program when the power is switched off. The one I have, doesn't have a back-up battery or memory module. Couldn't find a reference in the manual either.
Cheers.
From document I have on file, don't know where I got it.Probably an old KB when they were free. ("A long time ago in a galaxy far, far away")
Lifetime Of Batteries Used With The MicroLogix 1500. Question Lifetime of Batteries used with the MicroLogix 1500 Answer 1) What is the expected lifetime of the permanent,(not replaceable) battery? The expected lifetime of the permanent battery is (7-8) years under normal operation. The word normal is important. Extreme temperatures and other environmental conditions can shorten the battery life. 2) What is the expected lifetime of the replacement battery,(1747-BA)? If the replacement battery is added when the primary battery is close to the end of it's life an additional 3-5 years of life will be added. If the replacement battery is added when the processor is first installed, an additional 1-2 years of total life will be added 3) What is the function of the (2) batteries in the processor? The permanent battery is permanent. It is meant for memory backup. If the lifetime of the processor exceeds the permanent battery lifetime then a replacement battery, (1747-BA), can be installed to retain memory. The replacement battery can be installed in order to extend the total life. The batteries are wired in parallel with diode protection between them. 4) What is the expected lifetime of the battery in the RTC module? Both the 1764-RTC, and the 1764-MM1RTC, use a battery that cannot be replaced. The expected lifetime of this battery is (5) years.
Nice and Thankyou Mickey!
So basically I can install the second battery to insure it will stay backed up and the battery low indicator will tell me when to change that secondary battery again.
I know I'm not to touch the primary one at all.
Cheers!
Does the Old MicroLogix 1500 support Online Editing??? I am being told it did at some point but I think that is wrong...
2,378
Good day all. I have a Micro Logix 1500 (24BWA) that I can't seem to go online with the processor. According to the Rockwell Software Support page...
3,337
Hi to all, I am having trouble with my micro Logix 1500. I can get it to down load the program where it come up with remote run mode and when I...
7,767
Hello folks, I've been lurking in this forum for some time and find this site to be an excellent resource. :bow: I hope to contribute to it some...
8,100
I have the attached two programs and I can't understand how he is calling the panelview screens. In rung 33 of the messages section I'm trying to...
5,449
