Micro Logix 1500 communications problem
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Good day all. I have a Micro Logix 1500 (24BWA) that I can't seem to go online with the processor. According to the Rockwell Software Support page I can use RSlogix 500 for this. It has a Panel View 300 micro (cat#2711-M3A19L1). Could someone please tell me what the config settings are for this? Thank you.
Your PV supports DH485 protocol. If your ML1500 only has one comm port then it's configured for DH485 protocol.
If your computer has a real serial port then use the 1747-PIC/AIC+ driver. If your are using a USB port then you will need a 1747-UIC ( USB to DH485 converter)
Or you can toggle the port on your ML1500 to it's default setting by using the "Communication Toggle Push Button"
See pdf below for how-to
Does the Old MicroLogix 1500 support Online Editing??? I am being told it did at some point but I think that is wrong...
2,377
Hi there, Just wondering how the Micro Logix 1500 keeps the PLC program when the power is switched off. The one I have, doesn't have a back-up...
2,214
Hi to all, I am having trouble with my micro Logix 1500. I can get it to down load the program where it come up with remote run mode and when I...
7,764
Hello folks, I've been lurking in this forum for some time and find this site to be an excellent resource. :bow: I hope to contribute to it some...
8,099
I have the attached two programs and I can't understand how he is calling the panelview screens. In rung 33 of the messages section I'm trying to...
5,448
